Old 06-08-2007, 11:49 AM   #1 (permalink)
john1_83's Avatar
john1_83 is on a distinguished road
Default wm6 upgrade
i was told by a verizom tech that the wm6 upgrade will be available (free) for q owners after the new samsung wm6 device rolld out later this year.
while i cannot guarantee the validity of this statement i believe that he was telling me the truth as he did not beat arond the bush or tey to give me a bs answer when i asked about upgrading to wm6.
john1_83 is offline
Old 06-08-2007, 11:56 AM   #2 (permalink)
anything regarind WM6 is still up in the air...it all depends if VZW wants to make an upgrade...
there is tons of speculation and hear say....only time will tell i suppose....
Old 06-08-2007, 12:00 PM   #3 (permalink)
i'm with Scott... i will believe (& consider using it) when i actually have it. ot be completely blunt (which i usually am) it's almost like "sado masochism", people dwelling and keep talking about something -WM6 in this case- that is pretty unsure at this point.. i don't get it.
Old 06-08-2007, 12:09 PM   #4 (permalink)
john1_83's Avatar
not trying to beat a dead horse, just thought ppl might want to know. i have a feeling that the guy is right. anyway regardless of verizon releasing it, i am sure that someone will have it sooner or later
john1_83 is offline
Old 06-08-2007, 12:16 PM   #5 (permalink)
there are already hacked versions out there...a simple google search will find you something...i dont believe anyone has successfully installed it though
Old 06-09-2007, 04:21 PM   #6 (permalink)
dima is on a distinguished road
I have read on other forums that WM6 will be available free for the Q around the time the new smartphones are introduced this fall, assuming the ITC ban on Qualcomm imports is recinded or settled. Ughhh....
dima is offline
