Old 04-17-2007, 08:36 AM   #1 (permalink)
jetsafl is on a distinguished road
Exclamation Wireless Sync Help, Connecting but not syncing
I was able to get wireless sync installed on my work PC and I am able to set it up for my lotus notes. The monitor software runs and connects to the wireless sync website but never sends any data. I had this working on an old work PC but can't get it up and running on this new one. Here is the log from my wireless sync website:
PC Monitor - 04/16/2007 10:20:53 AM - Synchronization started
PC Monitor - 04/16/2007 10:20:51 AM - Synchronization started
Connection Info
Connection type: Network
Device name: NYK000184862
Sync via: Sync (user initiated)
Encryption: AES
Bytes in/out: 1114/1769 (* actual over the air count may be higher)
Duration: 00:02
Software Updates
Software - Up to date.
Backups - Up to date.
File & Website Updates
Files - Up to date.
Websites - Up to date.
Can anyone help me think of things to try and get this up and running?
jetsafl is offline
Old 04-17-2007, 07:30 PM   #2 (permalink)
pyrobling's Avatar
pyrobling is on a distinguished road
Send a message via AIM to pyrobling Send a message via Yahoo to pyrobling
Wireles Sync servers have been down off and on the last 24 hours.
This may be why it is not syncing. If it is not working by EOB tomorrow then something else may be wrong.
-SENT FROM MY Q!!
ADAM in Oregon
Text JOIN EverythingQ to 8762 to join Upoc's EverythingQ group
pyrobling@gmail.com
blingsthing.blogspot.com
blingselectronics.blogspot.com
......electronics reviews
If someone helps you thank them, use the icon under their post
pyrobling is offline
Old 04-20-2007, 10:00 AM   #3 (permalink)
This issue has been going on for weeks now so I'm not sure it has to do with the Verizon server. It just baffles me that the monitor software can make contact with the Wireless Sync website but can't push the data out there?
jetsafl is offline
Old 04-22-2007, 01:56 PM   #4 (permalink)
CO-Diver is on a distinguished road
I don't sync to Notes, but I've got to believe something's missing in your configuration.
The last lines of my sync log show how many messages went into what mailboxes. Did your sync log always show just what you've indicated? If not, then I'd recommend you check out the PC settings and the server settings.
Sorry I'm not much more help.
CO-Diver is offline
