Originally Posted by jim9112 the verizon guy probably wasnt so much giving you the run around as not wanting to quote you at a price since he has no idea whats a normal amount of emails for you. i think its like 2 cents a k of info, if your depending on your phone for buisness email i would get a data plan |
You're right Jim.
No telling how many megabytes it will be to load. If you have the $40 data plan with the 450 minutes, then you are on the America's Core Choice plan. You get a $5/month discount. There is also Core Extra for $109.99 which is 1350 mins and $30 for data, and Core Max which is $169.99 for 4000 mins and $20 for data.
If you have this plan there is no additional charge. It doesn't matter if you use a minute to load since it will not use any of your minutes while you are online. What the VZW guy was trying to explain is that if you DO NOT have the data plan, you pay $0.015/kb which totals out to $15/1mb. This means only 3mb and you are back up to the price of the unlimited data plan.
If you stay on the plan that you are on you can sync all you want and never worry. Welcome to the Q and EverythingQ forum.
-A
