Originally Posted by lexicon you won't need to master reset in order to get it back. you'll just need to find the original file. All the files in the start menu are merely shortcuts and can always be replaced/substituted/deleted...etc. Go into your windows folder and enable view hidden files and system files. If you can't remember the name then look for the icon. If you can't remember that then you'll need to tell us what was it's function - if you can't remember it's function then I can't help but think that you don't really need that file; seeing as how's it's been gone and you haven't really missed out on it's functionality. the more info you can give the more people can help. What did it do, what did the icon look like; what order was it in on the page? Different carriers sometimes put on different apps, try seeing if you can borrow a phone and find the icon - heck go into a store and see... Good luck and keep us updated. |
I found the original program, and created a new shortcut. The problem is the name of the shortcut is not the same as the program's exe file. So it works, but the symbol & shortcut on my desktop do not work. All I need now is the full name of the shortcut in the windows/start menu/ folder.
is has something to do with VZW wireless & sync.ink
