Originally Posted by n99hockey are you guys trying to have it backup your data for you?
if so try backing it up manually and see if you can skip that step
worked for a member doing an update last night |
No it is not even asking about a backup.
The moto software does a connect.
Then it checks and says that there is an update available.
then it starts to install. The Q9c show it is booting from flash and that the USB cable is connected. Then the error shows up.
