Originally Posted by xmaveric Let me clarify a little bit here:
The Verizon Q has 3 email modes:
Wireless Sync Exchange/outlook
Wireless Sync POP
Outlook Express POP
Wireless Sync has two modes: Exchange/Outlook Sync, and POP Sync. You can use these both at the same time. The Exchange Sync requires a PC Monitor on your computer that monitors your MS Exchange mailbox and instantly pushes the changes to your device. (I usually get emails on my device before I get them from Outlook in cached mode.) This is configured on wirelesssync.vzw.com. From that website you can also add POP accounts to have wireless sync check for you, at certain intervals. All emails using Wireless sync, whether they be from Exchange or from POP will be combined on your Q under the "Outlook Email" folder.
The other way to get POP mail is to set up the device itself to check a POP mailbox. You can do this by going into Outlook Express Portable (the email app on the Q) and going to menu > options > New account. The advantage of setting up a pop account in this manner is that it keeps the emails from this account separate from your main Outlook emails (I use Wireless Sync on my work computer, and use POP to check my personal mailbox.) On the welcome screen you will be able to distinguish which account has a new message. You can set this up to check every 10 minutes or longer, or to only check when you do a send/recieve. |
FYI.
You can also sync with an Exchange Server without using the VZW Sycn. Its actually very nice, fast, and works really well. We at our company all love it.
There is a little bit of setup, but for the most part is very easy!
D
