Old 06-30-2008, 12:18 PM   #11 (permalink)
jerkules's Avatar
jerkules is on a distinguished road
Originally Posted by Tony Bag o Donuts View Post
I agree with your agree...and raise you another agree.
It's agreed then.
Agreed?
--Jerk
jerkules is offline
Old 07-07-2008, 04:51 PM   #12 (permalink)
JustPureChaos is on a distinguished road
ok same thing happened to me. water damage and when it fell in the toliet it cracked the screen and an Assurion replacement arrived at my door just now. But will I run into problems when I send my broken one in? Will they see I modified it and try to F me for it?
JustPureChaos is offline
Old 07-07-2008, 05:13 PM   #13 (permalink)
sherri's Avatar
sherri is on a distinguished road
Send a message via AIM to sherri
What kind of modifications? I don't think they care, because they would have done the same thing if you lost the phone....they never would have found out about the mods. then, right? If the carrier was replacing it due to a manufacturers defect, and the "defect" was because you did something, then I could see them giving you a problem.
Assurion Insurance is a separate entity. They are supposed to cover physical damage to phone NOT due to mechanical problems...theft/water damage/cracked screen/etc...
sherri is offline
The Following User Says Thank You to sherri For This Useful Post:
JustPureChaos (07-07-2008)
Old 07-07-2008, 05:17 PM   #14 (permalink)
word. thanks a lot.
Old 07-07-2008, 05:55 PM   #15 (permalink)
dafoxs's Avatar
word. thanks a lot.
dought they have time to look at every phone they get back. you will probably see it on EBay and someone will be posting some problem with it.
dafoxs is offline
