Old 05-15-2008, 10:07 AM   #21 (permalink)
Tony Bag o Donuts's Avatar
Originally Posted by dowop View Post
This is for verizon only. Put the URL in on your Q IE browser and install the .CAB files directly or hit it from a PC and download the .CAB files to your Q.
Not sure what else you are asking....
is this the wrong site then?
http://www.oz.com/
My photography website.
leave comments, etc.
Tony Bag o Donuts is offline
Old 05-15-2008, 10:17 AM   #22 (permalink)
I FEEL STUPID...
Old 05-15-2008, 11:23 AM   #23 (permalink)
dowop is on a distinguished road
Ahhh... now I see, you missed the link.
Hope this helps.
dowop is offline
The Following User Says Thank You to dowop For This Useful Post:
Tony Bag o Donuts (05-15-2008)
Old 05-15-2008, 11:42 AM   #24 (permalink)
yep it does.
going to try it over the weekend.
Still want to find the app that is causing battery drain.
are you on the 30.00 plan by any chance?
Old 05-15-2008, 11:52 AM   #25 (permalink)
Originally Posted by Tony Bag o Donuts View Post
yep it does.
Yup, I'm on the 29.99 plan. I used to be on the 44.95 and that gives you Wireless Sync and the 29.99 does not. My CS rep told me about the version of Oz Mobile email. I currently use it for AOL and Yahoo mail, but I've not messed with it w/gmail yet.
dowop is offline
Old 05-15-2008, 11:54 AM   #26 (permalink)
cool i keep confusing push email with the wireless sync/ exchange server issue with the plans.
Old 05-15-2008, 11:57 AM   #27 (permalink)
L0c0's Avatar
L0c0 is on a distinguished road
Is this a pop/smtp "push" client? or can it be used w/exchange?
and whats the difference from the pop client the Q already has?
*wait, it must include contacts and calendar options to sync right?
L0c0 is offline
Old 05-15-2008, 12:00 PM   #28 (permalink)
The pop client the Q already has cannot push email by default I believe. At most you can set it for checking every 15min which will kill your battery.
The Following User Says Thank You to Tony Bag o Donuts For This Useful Post:
L0c0 (05-15-2008)
Old 05-15-2008, 12:05 PM   #29 (permalink)
Yes, this is a POP3/IMAP push client (don't confuse SMTP... whole different thread) - I don't believe that you can use it w/exchange. For that you'll need Wireless Sync or something like mail2web and then configure your ActiveSync accordingly. To get Verizon WirelessSync you can not be on the 29.99 plan.
Are you talking about Outlook that is pre-installed on the Q? If so, Outlook is a time based 'Pull' email client application. The Mobile Email by verizon is a 'Push' style and will save considerable battery life.
dowop is offline
L0c0 (05-15-2008)
Old 05-15-2008, 12:09 PM   #30 (permalink)
L0c0's Avatar
And just to add:
I use my cable providers mobile.based webClient to check email. I have it setup to send me a txt msg to xxxxxxxxxx@vtext.com when I recieve a new mail...its very convienent because it give me the first part of the msg and if I need to I just hop over the PIE and see the entire message. But I can't sync contacs or my calendar...so that sux
L0c0 is offline
