Old 04-12-2008, 08:03 PM   #1 (permalink)
capo8488's Avatar
capo8488 is on a distinguished road
Default uninstalling programs..
what is the best way to delete programs that you dont need anymore? i have sktools...will that work? when i delete stuff i feel like its still on the phone..
nevermind, had to master reset...got stuck on the windows screen... =(
capo8488 is offline
Old 04-12-2008, 09:17 PM   #2 (permalink)
for future reference
start
settings
remove programs
Old 04-12-2008, 09:41 PM   #3 (permalink)
rainmakerrc's Avatar
And if for some reason the program doesn't show up there, hook up your Q to your PC via Active Sync, and use the Remove Programs function in Active Sync on your PC.
Rob
Apps on my Q9c
rainmakerrc is offline
Old 04-12-2008, 09:42 PM   #4 (permalink)
aaaaaaaaaaaand if you still dont see it that means its in ROM and cant be deleted
Old 04-14-2008, 12:13 AM   #5 (permalink)
capo8488's Avatar
ha thanks a lot...I just figured there would be like a ''recycle bin'' that needs to be emptied from time to time..
capo8488 is offline
Old 04-14-2008, 12:17 AM   #6 (permalink)
TreeFrog's Avatar
Only if you have resco explorer there is.
TreeFrog is online now
