Old 02-06-2008, 09:39 AM   #11 (permalink)
ajlaurid is on a distinguished road
FYI...
These terms are located here:
http://www.verizonwireless.com/b2c/f...agingterms.jsp
ajlaurid is offline
Old 02-12-2008, 03:47 PM   #12 (permalink)
rickross is on a distinguished road
Originally Posted by Breny View Post
I activated my new Q9m last night and the Verizon rep told me that all txt messages AND picture txt messages with not count towards my data plan (I chose Pay as you Go). I don't plan to use the internet. They both will count towards my $10 txt plan which is 500 txt messages OUT of network and unlimited IN.
She said they USED to charge you towards your data plan for PIX messages but they have changed that. Because I was very insistent on making sure Pictures WILL NOT count towards my data plan.
So I'm pretty happy with all that and now lets see what I'm charged BUT I am happy with what she said!!!
So is there any extra fee with "pay as you go" ? Like even a small amount?
rickross is offline
Old 02-12-2008, 04:04 PM   #13 (permalink)
rainmakerrc's Avatar
I don't think there's an extra fee to be on the pay as you go data plan, but the data prices are pretty high, so you need to make sure you don't accidentally use data for other things.
rainmakerrc is offline
Old 02-12-2008, 04:16 PM   #14 (permalink)
ok so would it be possible to get "pay as you go" and block data then use a wifi sd for internet usage when im at home or in other wifi areas?
rickross is offline
Old 02-12-2008, 04:19 PM   #15 (permalink)
I think the two are mutually exclusive - if you get a data block, then you won't be on pay as you go. Since the wi-fi card doesn't use a data plan, having a data block won't prevent you from using the card.
Old 02-13-2008, 06:25 PM   #16 (permalink)
peppersghost's Avatar
peppersghost is on a distinguished road
I only have unlimited texting but no data plan and the lady at Verizon told me it costs data to log into MSN Messenger, does anyone know more about this?
peppersghost is offline
Old 02-13-2008, 06:56 PM   #17 (permalink)
yea... IM'ing uses data, what more do you wanna know ?
potQ.
Old 02-13-2008, 07:03 PM   #18 (permalink)
JustPureChaos is on a distinguished road
So if IM'ing uses data..MMS uses data..Thus you need data plans for MMS.
That's the way I'm understanding I just spoke to a VZW rep and she said basically I won't be able to send/receive MMS msgs on my Q without a data plan because MMS uses data. I'll have to retreive send online at vzwpix?
JustPureChaos is offline
Old 02-14-2008, 02:35 PM   #19 (permalink)
felix822's Avatar
felix822 is on a distinguished road
Where did you buy the WiFi card?
felix822 is offline
Old 02-14-2008, 02:39 PM   #20 (permalink)
You can find them in lots of places. Google Spectec wifi, and you should be able to find a place to buy one from.
felix822 (02-14-2008)
