You would think that Verizon/Motorola could release an EMS program for Windows Mobile that would allow us to use the new standard. Anyway, I originally posted this in another forum:
I have the original Q and I've had this problems for a very long time now, It used to work at one time and then seemed to have stopped receiving multiple txt msgs from Verizon handsets.
I call
tech support last night and asked him to refresh my data settings and he did. He then asked if there was any specific problem he could help with. I told him my scenario.
VZW
Smartphone -> VZW Smartphone = multiple txt come through
VZW Handset -> VZW Smartphone = 1 txt msg and then the rest is cut off
My brother works for AT&T so I can verify this too.
ATT Smartphone -> VZW Smartphone = multiple txt come through
ATT Handset -> VZW Smartphone = multiple txt come through
I told him I know my phone isn't EMS capable, he then cut in and said yeah you just want to get multiple messages sent to your phone. He put me on hold and said he was going to go grab a handset to do a test.
When he came back on the line he said you're right. He had tested it and got the same problem on his personal Q9m. He didn't know this was even a problem and was determined to find a solution because it affects him too.
Anyway, I was on the phone with him for about an hour. I mentioned maybe there's a EMS->SMS setting . He tried everything and then put me on hold to go talk to his supervisor to see if there was a way around this. When he came back he said it's a network problems. I give credit to this guy for trying everything he could. I could tell I bummed him out because he was just as frustrated as me.
