Originally Posted by Needler56 i accidentily removed wireless sync, but with the help of a vzw tech, i was able to go onto the site and re-install it.
he had also mentioned that you can do a master reset to get wireless sync back.
since i downloaded it off the site, is the old wireless sync that i accidentily removed still on my phone somewhere taking up memory?? |
i don't think it is... it's most likely installed over where the previous was installed.
