Old 03-23-2007, 12:33 PM   #1 (permalink)
kfe22 is on a distinguished road
Desktop software Quick question
How do you make the icons on the home screen bigger, while keeping the text the same size... I tried changing it but everything was made larger...
Also, is there directions somewhere on here on how to download new home screens... I was looking through the site with no luck, help would be appreciated...
thanks guys and gals
kfe22 is offline
Old 03-23-2007, 12:43 PM   #2 (permalink)
http://www.everythingq.com/moto-q-new-user-guide
re. the icons, they can only be size 16 or 32 (mru icon-size="XX")
Old 03-28-2007, 05:44 PM   #3 (permalink)
pyrobling's Avatar
pyrobling is on a distinguished road
Send a message via AIM to pyrobling Send a message via Yahoo to pyrobling
I believe MSN Default is a Home Screen that will blow up your icons but keep everything else small.
For Home Screens....
Find the Screen you want.
-Go into Activesync
-Explore
-Windows Mobile Device
-Application Data
-Home
Dump the file you downloaded into this file. Then it will allow you to customize your Home Screen.
The two other settings for the Home Screen need to be set to Default after you pick your screen that you want.
Hope this helps.
-A
ADAM in Oregon
Text JOIN EverythingQ to 8762 to join Upoc's EverythingQ group
pyrobling@gmail.com
blingsthing.blogspot.com
blingselectronics.blogspot.com
......electronics reviews
If someone helps you thank them, use the icon under their post
pyrobling is offline
