Old 12-21-2006, 03:58 PM   #1 (permalink)
bennym516 is on a distinguished road
Default Question
I plan on getting the q soon, and i was wondering on Verizon if i get the pay per KB, how much do you think it would cost to use an instant messenger a month?? If that is the only data charges i used
Thank You In Advance
bennym516 is offline
Old 12-22-2006, 09:19 AM   #2 (permalink)
mad3963 is on a distinguished road
Virtually impossible question to answer as it would vary depending on how much IMing you do on a daily basis. Best bet is to try it for a month and see.
mad3963 is offline
Old 12-22-2006, 06:39 PM   #3 (permalink)
KMAS is on a distinguished road
Smile
I have the same question. I know at the Verizon store, they told me a typical website like CNN would be about 4MB of information. I also checked my daily emails and they are usually between 2-5kb.. so I'm guessing that would be a number close to what each IM would cost
KMAS is offline
Old 12-29-2006, 07:48 AM   #4 (permalink)
pyrobling's Avatar
pyrobling is on a distinguished road
Send a message via AIM to pyrobling Send a message via Yahoo to pyrobling
Just do the math on it. Say you use 5 megabytes in 1 month. 5 megs @ $0.015/kb will add up approximately $19.20. 5 megs is small. I used 280 megs last month...that would add up to 4200 if I didn't have unlimited but I am also using a lot more....especially at over 1.5 gigs this month
-Adam @ VZw
pyrobling is offline
