Old 02-15-2008, 09:24 PM   #11 (permalink)
saw your edit of the first post
your mms sound is the same as email sound...so if you have no email sound you have no ms sound
-Sent from my Q
itasor (02-16-2008)
Old 02-17-2008, 08:15 PM   #12 (permalink)
itasor is on a distinguished road
Something is using data. My data usage this morning on VZW.com's My Account page said 1.5kb. I just checked it and now it says 15.96kb, even though the data still says "since 2/16" (yesterday).
What is using data? I think that's only 24 cents of data but I still don't want any. I know the 1.5kb was from opening IE and having the VZW page load, but other than that all I've done is send PIX/FLIX messages and text messages. I don't have it syncing e-mail, NO other apps installed besides the ones it comes with, etc.
itasor is offline
Old 02-17-2008, 08:43 PM   #13 (permalink)
dont know
why dont you do the password for data access hack...so you know when you are about to use data it will prompt you for a password
Old 02-17-2008, 09:45 PM   #14 (permalink)
dont know
I was avoiding hacking anything, but I guess I'll have to. Do you have a link to the modification? I found it once but now I can't find it again.
Also, is it known to work right on the Q9m? I thought what I read was very old and for the original Q.
itasor is offline
Old 02-17-2008, 09:59 PM   #15 (permalink)
some hacks work for both
open the sticked hack thread (for the orignal Q) and then click the password hack link in the 2nd post
Old 02-17-2008, 10:46 PM   #16 (permalink)
I know, I was curious if anyone has done this particular hack to their Q9m with success.
Also, I did click that link, but the page it goes to has no info on the hack. Maybe the links changed.
itasor is offline
Old 02-17-2008, 11:02 PM   #17 (permalink)
it did
its right here
http://www.everythingq.com/forum/mot...html#post15883
it was on page 4 not 5
Old 02-18-2008, 10:19 AM   #18 (permalink)
it did
its right here
Ah, ok thanks, so it's the same on the Q9m? I need to get a registry editor installed and then I'll give it a try. If I skip the modification to the VZQ MMS does that mean it will use the data for picture messages without asking me for a password (which would be nice).
Thanks!!!
itasor is offline
Old 02-18-2008, 11:11 AM   #19 (permalink)
Thanks!!!
i dont konw you will have to try it out
Old 02-18-2008, 03:06 PM   #20 (permalink)
Well I have a Mac, but I have XP installed as a virtual machine (VMWare Fusion).
I can't get the Q9m to work in Windows, but I'm not sure it has anything to do with not having a PC. When I have the list of USB devices to "send" to the Windows operating system, the only thing I have see is "Motorola Remote USB device", which doesn't do anything.
Do I need to install Active Sync to use it through Windows? I was hoping to use the Mobile Registry Editor program to avoid installing any programs on the actual phone.
itasor is offline
