Old 07-18-2008, 06:30 PM   #1 (permalink)
tmwight is on a distinguished road
Default No WiFi with Verizon?
I'm sure this was discussed earlier. Can you use the Internet Explorer on Verizon's version of the Q? I am under the impression that they want you to pay for their data plans rather then being able to use free wifi. If this is the case I wont be buying this phone.
tmwight is offline
Old 07-18-2008, 06:42 PM   #2 (permalink)
sherri's Avatar
sherri is on a distinguished road
Send a message via AIM to sherri
The original Q does not have wifi (any carrier, I believe...) I think the 9Qc for Verizon can do wifi...
Sherri
(still have no clue what I'm doing, but at least I'm having fun doing it!!)
(If someone helps you out, click the "Thank You" by their name!!)
sherri is online now
Old 07-18-2008, 06:44 PM   #3 (permalink)
PacoJr67's Avatar
the Q9c should be able to as long as you have a WiFi mini SDIO card
PacoJr67 is online now
Old 07-18-2008, 06:51 PM   #4 (permalink)
sherri and pacojr67 are correct....you need to have a Q9 to use a wifi card
never has any of the Q1's been able to use wifi...
you can use internet explorer on the Q with out a data plan but they will charge you per KB
Old 07-18-2008, 06:57 PM   #5 (permalink)
So I have to have a card? I can't just go onto the net using the IE?
tmwight is offline
Old 07-18-2008, 06:58 PM   #6 (permalink)
to use wifi you need a wifi card (which the original Q can not use)
you can just go on the net but like i said verizon will charge you per KB
