Old 07-08-2008, 09:58 AM   #1 (permalink)
BostonBoy23 is on a distinguished road
Post Mini SD WiFi Card
I'm thinking of buying a Mini SD WiFi Card, I haven't read to much into it. But if you purchase one of these, is it true you can connect to a wireless internet and not be charged? I don't want to spend the money and be charged from Verizon for using the internet. Does anyone know or used a Mini SD WiFi Card, and know how it all works? Thanks.....
Also if any brands are the best to go with, let me know....
BostonBoy23 is offline
Old 07-08-2008, 09:59 AM   #2 (permalink)
yes thats the point of wifi being able to wireless internet hot spots
please search for wifi...many threads on this!!!
Old 07-08-2008, 10:01 AM   #3 (permalink)
comptiger5000 is on a distinguished road
They work, but use A TON of battery.
Q9m rocks.
comptiger5000 is offline
Old 07-08-2008, 10:47 AM   #4 (permalink)
Once I slide the card into the phone, I have the Motorola Q 9c, how do I set the card up to work with my wireless internet? Do I have to go into connections and such?
Old 07-08-2008, 01:25 PM   #5 (permalink)
http://www.everythingq.com/forum/ver...tml#post210382
Old 07-09-2008, 09:40 AM   #6 (permalink)
The link you provided, link right back to the Thread. Not sure if it that was the purpose or if you were giving me a link to a thread about my question?
Old 07-09-2008, 03:10 PM   #7 (permalink)
Thomas M is on a distinguished road
You have to install the drivers but after that wifi support is built into Windows Mobile. Just open the connections mannager you will see the options.
Thomas M is offline
Old 07-11-2008, 11:23 PM   #8 (permalink)
rapmasterj729 is on a distinguished road
my card worked for a day and now just tells me no networks are available even though there are ones
rapmasterj729 is offline
Old 07-12-2008, 08:36 AM   #9 (permalink)
Reboot your phone, or reseat the card. They aren't perfect.
Q9m rocks.
Old 07-12-2008, 01:22 PM   #10 (permalink)
i did reboot the phone i dont know how to reset the card
