Originally Posted by kennedy3323 I called to remove the Unlimited Data plan on my Q and was told by the CSR that I have to have the package for the phone to work. Thats not true is it? Now if I wanted to use the phone for data then I would need it. But for just scheduling and phone calls I don't. |
the phone will still work and data will still work...you will just get charged and a per kb basis if you use data
so make sure you either put a data block on with your provider or go to the hack section and use the hack that makes you input a password before data is used
