Originally Posted by coolguy827 Do not listen to anybody above, u can buy an antenna for about $50. |
You sure can, but don't waste your money on a 0db (unity) antenna - you'll need at least a 3db to help JUST A LITTLE. Because of the SAR issues, a CDMA (Verizon) phone transmits at less then 1 watt (GSM is less then 2 Watt). (Heck, I can buy a FRS/GMRS two-ways with more power.)
Anyway - on the Verizon network, you are thowing your money away if you are in a fringe area with anything less then an amp. If you don't care about up time, then feel free to take your chances with just an antenna. Since you'll need an antenna anyway with an Amp - you can try to walk before you run.
I stand by my last post - you need a combination of Power and DB's to make a real difference.
My (educated) 0.02
