Old 05-02-2007, 07:50 AM   #1 (permalink)
snoose27's Avatar
snoose27 is on a distinguished road
Default How Can I save Songs
So Now I have Active Sync
And A 1 Gig Mini SD Card
I have down loaded the Active Sync Software & Tested it,... It Works..
I have put my 1 G SD card into the side of the phone..
But heres my prob...
I still can't save / add additional songs... Why..
FYI.. I am a computer Idiot... I just assume this stuff automatically works on its own????
Help Please...
Stay Hard,
Snoosese27
- Keep your stick on the Ice -
snoose27 is offline
Old 05-02-2007, 08:19 AM   #2 (permalink)
make sure your able to see the card through file manager...you should see a folder called 'storage card'
if you dont see it take it out and put it back in and turn off and on the phone the then check again....if still nothing then you might have to format it on your PC and try again.....
