Old 02-27-2007, 12:22 AM   #11 (permalink)
qnoob's Avatar
Originally Posted by troutseth View Post
Try a different Verizon store. I have had to switch out two Treos and one Q and I had no issue at all.
yup, guess that's what I'll have to try, thanks.
qnoob is offline
Old 02-28-2007, 09:11 PM   #12 (permalink)
gmplr831 is on a distinguished road
Send a message via AIM to gmplr831 Send a message via Yahoo to gmplr831
Originally Posted by eciracing View Post
I just got my Q (Black) from Verizon yesterday. All in all, I'm fairly happy. I am having a VERY annoying problem though. I have had the whole system freeze up on me numerous times. After waiting a couple of minutes, I end up having to remove the battery to unfreeze it. It has happened 3 times when trying to "Kill" a internet explorer webpage under the task manager, and 1 time while simply adjusting the sounds for various alerts in the settings manager.
Anyone else have this problem? I'm still within my 15 day trial, so I will send it back if this is the way it operates.
I had this exact problem and just took it into verizon, they gave me a new one, and all is well.
Jeff Hewitt - Sprint Q User
Ask me about technology, as i am a geek when it comes to this stuff!!
FRESH OUT OF REFERRALS FOR SPRINT! til 2-1-08!
If somebody helps you, boost their reputation.
gmplr831 is offline
Old 03-02-2007, 07:12 PM   #13 (permalink)
waterengineer81 is on a distinguished road
Default Same Frozen Q Problem
I had the same deal. I bought my first Q 2 days ago. The first day my Q froze up 12 times! I took it back that night to get it swapped out and now my second one froze up a couple of times today. I called and told me to do a master reset. I did that and I will update you on that if that works out.
waterengineer81 is offline
Old 03-06-2007, 10:21 PM   #14 (permalink)
qnoob's Avatar
good to hear of good resolution . . . looks like this is an ongoing issue and VZW appears to be eating the time and money to just replace Q's and minimizing negative experiences with customers.
qnoob is offline
Old 03-06-2007, 10:29 PM   #15 (permalink)
Default Frozen Q contiunes
Well I did a master reset and it seems to be a working alot better. I still do get the ocassional frozen q, but not nearly as much as I did before. I really don't know what to do with it after this. Let me know if anybody finds a resulation for the problem.
Old 03-06-2007, 10:35 PM   #16 (permalink)
qnoob's Avatar
out of my 3 Q's so far, I've had the most freezes / random shutdowns with the VZW "version" that said "Get Applications" instead of "Downloads" on the VZW Full Layout home screen.
I don't know what the versions these were (or if it even mattered?), but my current Q has "Downloads" and that's been the most stable.
qnoob is offline
