Originally Posted by My-Q You better check with VZW for your answer. That is my suggestion.
IF PIX messaging is dependent on data, then how can my wife and son send PIX without the data plan. |
You can send pix without a data plan. As long as your data isn't blocked. It just cost about 3 bucks a pop. Now as far as your wife goes. Keep in mind that the Q works differently from most phones. It uses Data not Minutes like most of you typical cell phones.
