Originally Posted by qnoob If you're choosing between the Treo 700w and the Q, they both run Windows Mobile so all you're really comparing is form-factor. The 700w has a stylus & touchscreen, the Q uses a scroll wheel (a la blackberry). Take your pick.
It's much different if you're comparing the Palm-based Treo 700p to the Q. |
I definately want to go the Windows Mobile route. Let me ask a couple of specifics.
1) I know it's not built in to the Q, but is there a way to use WiFi? You know, jump onto your home wireless network, or maybe a hotspot? Or is the internet accessed only if you subscribe to one of the data packages?
2) If you do have a data package, am I able to access my home computer somehow? A buddy of mine uses the Treo 700w, and can actually access his home computer as if it's a remote desktop connection.
3) What exactly can you use the infared port for on the Q?
Thanks for all you prompt responses guys, it's very helpful.
