Old 02-13-2007, 10:48 PM   #11 (permalink)
qnoob's Avatar
Originally Posted by qnoob View Post
If you're choosing between the Treo 700w and the Q, they both run Windows Mobile so all you're really comparing is form-factor.
You know what? I think I'm wrong about this. I believe the Q runs the Smartphone version of WM while the Treo runs the full-PDA version of WM (so I believe you can edit Office docs out of the box). Or does the Q and Treo both run the same version of WM? Can someone else confirm this?
qnoob is offline
Old 02-14-2007, 01:05 AM   #12 (permalink)
gmplr831 is on a distinguished road
Send a message via AIM to gmplr831 Send a message via Yahoo to gmplr831
Quick answer for #2 in the posts above. Use avvenu. Set it up on the computer you want to activate and use avvenu from the moto q and you have full access to your computer from a remote location for free. Also allows you to stream music if you use itunes.
gmplr831 is offline
Old 02-15-2007, 09:18 AM   #13 (permalink)
My-Q's Avatar
My-Q is on a distinguished road
Send a message via Yahoo to My-Q
"3) What exactly can you use the infared port for on the Q?"
I used the infrared port to transfer my documents, contacts and calender from my PDA to my Q. You should be able to transfer files from one Q to another Q, though I've not tried it. You would have to get two Q users together to find out. Theoretically (if you have the app) you can print from your Q's infrared port to a printer so equipped. I think I saw a app that you can use to change the channels on your tv using the infrared port.
You may be going to Heaven, but when I die I'm going to Fiddler's Green.
Lugh Lamhfhada
Senior
Criminal Justice/Homeland Security
Austin Peay State University
Cavalry Trooper
HHT 1/278th ACR
My-Q is offline
Old 02-15-2007, 09:22 AM   #14 (permalink)
My-Q's Avatar
Because the Treo has a touch screen, it has a slightly different version of WM5.0. The VZW's Treos have the full set of Office apps.
Lugh Lamhfhada
Senior
Cavalry Trooper
HHT 1/278th ACR
My-Q is offline
Old 02-15-2007, 01:36 PM   #15 (permalink)
eciracing is on a distinguished road
Thanks for all the help guys. I think my mind is made up for the Black Q. It's just too sweet of a phone to pass up on.
An earlier poster mentioned something called "avvenu" for accessing your home computer from the Q. Where can I get some info on this?
Thanks again.
eciracing is offline
Old 02-15-2007, 01:52 PM   #16 (permalink)
mccarob's Avatar
mccarob is on a distinguished road
Send a message via MSN to mccarob
Thanks again.
A search on Google for Avvenu returned: http://www.avvenu.com
mccarob is offline
Old 02-15-2007, 04:26 PM   #17 (permalink)
SafeHarbor's Avatar
SafeHarbor is on a distinguished road
How about the 700w only has about 10 MB free after all the phone stuff loads? A better comparison would be the Q to the Treo 750.
SafeHarbor is offline
Old 02-19-2007, 03:53 PM   #18 (permalink)
Just wanted to say thanks for all the info guys. I ordered by Black Q this past Saturday. Should be here by the end of the week.
Old 02-19-2007, 03:54 PM   #19 (permalink)
My-Q's Avatar
Great! I'll think you'll like it!
Lugh Lamhfhada
Senior
Cavalry Trooper
HHT 1/278th ACR
My-Q is offline
Old 02-19-2007, 05:06 PM   #20 (permalink)
Default Avvenu
Its an easy way to access your files on the go for free. You simply install the program on the host computer and then access it from any other computer connected to the internet including mobile phones.
Jeff Hewitt - Sprint Q User
Ask me about technology, as i am a geek when it comes to this stuff!!
FRESH OUT OF REFERRALS FOR SPRINT! til 2-1-08!
If somebody helps you, boost their reputation.
gmplr831 is offline
