Old 03-24-2007, 11:04 PM   #11 (permalink)
Originally Posted by djvirtue1 View Post
To summarize all this, are you all saying that using software like, IM+, Agile, Mundu, etc. are ONLY using data calls. I just download the trial version of Agile and started using AIM on there. I hope this is true because like most of you I do not want to end up with a huge TXT messaging bill.
Thanks all
they only use data not sms messaging
Old 03-27-2007, 11:45 AM   #12 (permalink)
mrtune is on a distinguished road
Using msn or yahoo doesn't use text messages, only data. If you want to use yahoo messenger via the internet, go here.
http://mm.yahoo.com
Mine links to the get it now page when I click the link via yahoo as well. Works fine if I'm plugged into the pc though, lol.
John Dimo
mrtune is offline
Old 03-28-2007, 05:57 PM   #13 (permalink)
pyrobling's Avatar
pyrobling is on a distinguished road
Send a message via AIM to pyrobling Send a message via Yahoo to pyrobling
All messenging services available with Agile Messenger.
www.agilemobile.com
-A
ADAM in Oregon
Text JOIN EverythingQ to 8762 to join Upoc's EverythingQ group
pyrobling@gmail.com
blingsthing.blogspot.com
blingselectronics.blogspot.com
......electronics reviews
If someone helps you thank them, use the icon under their post
pyrobling is offline
Old 04-13-2007, 01:28 PM   #14 (permalink)
jdawkins is on a distinguished road
Only problem with agilemobile is you must install from your computer. They have a link on their website to the 'expert' page to download a .cab file directly to your Q. Of course it actually downloads a .zip file which cannot be handled on your Q. I could not find any links for a .cab file on their website, so you'll need to download an .exe and then sync to your phone.
www.agilemobile.com
-A
jdawkins is offline
Old 04-13-2007, 01:33 PM   #15 (permalink)
pyrobling's Avatar
NOPE
If you have the Documents To Go program on your phone, it will handle the .ZIP file. I installed the trial so that I could check out the program...went to the site and it download and then extracted the Agile ZIP file in Documents To Go while I was driving.....(cause that was smart of me) and now i'm using it fine.
-A
ADAM in Oregon
pyrobling@gmail.com
