Old 05-15-2007, 06:05 PM   #1 (permalink)
bbhair is on a distinguished road
Default Can't keep a connection streaming? Please please help
So, been trying for several days with multiple forums and I have no idea how to fix this. I have multiple streaming radio stations and sirius radio working for a minute or so but then it loses the connection. How can I configure or load something on the q to get it to stop losing the connect after a minute?
Please please help.
I saw for other phones besides the q you can set the idle connection setting = none. From what I have read and seen in other forum's you can't do that with the Q.
by the way I am using WM5 from geekstoolbox and TCPMP
bbhair is offline
Old 05-15-2007, 07:57 PM   #2 (permalink)
do you have a EVDO connection or a 1X connection...or does it fluctuate between both...could just be loosing its connection speed
Old 05-15-2007, 11:20 PM   #3 (permalink)
I have tried in different locations and it does the same for a EVDO or 1X connection. The developer said you have to set the connection idle = none but with the Q you can't do that as far as I know. How have others gotten this to work with the Q? Maybe only works with the new version of Verizon software? I am on the MO2.
bbhair is offline
Old 05-16-2007, 10:31 AM   #4 (permalink)
Maybe VZW is doing it. I suppose it's possible they can break the connection if they detect you are streaming content since it violates the TOS.
scottjb is offline
Old 05-16-2007, 10:33 AM   #5 (permalink)
hmm, for those that have it working today did you upgrade to the MO3 Verizon update?
bbhair is offline
Old 06-21-2007, 08:52 AM   #6 (permalink)
jbshaps is on a distinguished road
Send a message via AIM to jbshaps Send a message via Yahoo to jbshaps
System Tools or Repair
I am having the same problem. Times out after exactly 1 minute. How do we go about getting the MO3 update, anyway? I have been on the road for months, and have not been able to check on things like this.
jbshaps is offline
Old 06-21-2007, 10:44 AM   #7 (permalink)
Before you do the upgrade try unchecking wireless sync push or time intervals settings and then try. It worked for me. When done with sirius I go back and turn the settings back on. Kind of a pain but sirius works great and doesn't timeout with wireless sync off . Then you can try the upgrade if that doesn't work.
For the upgrade do a quick search on MO3 there are great instructions. At least there is on http://www.qusers.com/forum/. Basically go to Motorola website using your sync cord and it walks you through it. Then reinstall all that you want, don't forget to call and have your carrier reinstall your services. MAKE SURE TO BACK EVERYTHING UP AS THE UPGRADE ERASES EVERYTHING. Hope this helps.
bbhair is offline
Old 06-21-2007, 10:51 AM   #8 (permalink)
Need Help
Where is the Wireless Sync push or time intervals setting located?
Never mind...I'm an idiot. I found it.
jbshaps is offline
Old 06-28-2007, 11:50 PM   #9 (permalink)
dmascot is on a distinguished road
Default Same Problem so I called Verizon
I was having the same problem so I called Verizon. The tech rep threatened me with termination. She said that streaming was illegal on the Verizon network, and that there was now a 5 gigabyte limit per month on downloads. This really pissed me off, so I begged her to terminate my contract, so I could go to AT&T and the Iphone. Verizon has no clue as to how their customers want to use the internet. I think they are in for a big surprise when they lose customers to AT&T.
dmascot is offline
Old 06-28-2007, 11:54 PM   #10 (permalink)
Default Update?
Also I wouldn't be in a hurry to try that update. Who knows what limits they put in that thing.
dmascot is offline
