Originally Posted by ibanez57 I've been told a different story depending on who I ask whether its a Verizon store or the online help. Some say I can get a Q with only a txt plan, some say I need data, some say I can not get data but I will be charged every 5 minutes when it updates email. Anyone have a good definate answer? |
I don't think any one person can give a definite answer unless they work with Verizon -- and even they don't always know as you've found out.
However, the thing about being charged every 5 minutes is likely garbage. First, if you don't set up E-mail, how would it check? Second, E-mail can only be checked every 15 minutes at most (unless WM 6 has changed or you're using push).
Try asking for a data block.
Steve
