Old 10-14-2007, 09:50 AM   #11 (permalink)
Pony99CA's Avatar
Default Pay As You Go Data Plan Cost
Originally Posted by deejmemixx View Post
if you have no data plan and you get online, or recieve email you will be charged .005 cents per kilobyte you use.
Actually, I believe that's $0.015 per KB, so it's three times worse than you think.
Steve
Silicon Valley Pocket PC
http://www.svpocketpc.com
Pony99CA is offline
Old 10-14-2007, 09:57 AM   #12 (permalink)
Pony99CA's Avatar
Default Semantics
Originally Posted by Eugene View Post
The post before you said "if you have no data plan". I'm saying you can't have no data plan, you have to have a data plan to get the phone. What you describe as having no data plan is actually having the pay as you go data plan.
Most people say "no data plan" as shorthand for "no separately billed data plan". It's like saying that you have "no text message plan"; you actually do have a pay-as-you-go plan (unless you get text messages blocked).
However, you can get a data block (although maybe not when you purchase the phone), in which case you do have no data plan at all.
Steve
Pony99CA is offline
Old 10-14-2007, 08:33 PM   #13 (permalink)
jacobburke's Avatar
jacobburke is on a distinguished road
Send a message via AIM to jacobburke
I just switched back to my Q today with Verizon since I am passing my 'regular' phone off to a family member. I called customer service to do the equipment switch and they asked me if I wanted to block the data. I said yes since all I need this for is phone/text/calendar. I have tested IE and get a message telling me that this service is not available. So the data block truly does work. No needing to hack the registry. Hope this helps!
jacobburke is offline
Old 10-15-2007, 06:53 AM   #14 (permalink)
Pony99CA's Avatar
Default Data Block vs. Registry Hack
I don't think that anybody doubted the data block would work. However, the registry hack serves two purposes.
First, it allows you to access data when you want to, without worrying about a program doing it accidentally (or on its own).
Second, it allows MMS to still function on the Q, which seems to use data unlike most "dumb" phones where it uses minutes. If you have time, try sending and receiving a picture message and tell us what happens.
Steve
Pony99CA is offline
Old 10-15-2007, 07:51 AM   #15 (permalink)
Eugene is on a distinguished road
Steve
The Pay as You Go plan is billed seperate. And even with the data block you still have a data plan, the pay as you go plan, your just blocking yourself from using it.
I see so many people saying so and so got one without a data plan and that confusion comes from people calling the pay as you go plan "no data plan" so by calling it your own name your adding more confusion.
Eugene is offline
Old 10-15-2007, 08:19 AM   #16 (permalink)
Pony99CA's Avatar
Default No Plan
There may be a "line item" for it on your bill, but it's $0, which is not what I consider being billed. To be more specific, since you seem to want to be pedantic about it, there's no monthly cost for pay-as-you-go, so many people refer to that as having "no plan" (because plans are things you get charged for). You certainly get billed for the usage but not for the plan itself.
You're technically correct that you do have a plan, but I suggest getting used to people saying "no data plan" and realizing what they mean. I'm a big stickler for technical accuracy (as you may have noticed ), and even I don't debate that usage.
There's no meaningful distinction between a data block and "no data plan". There's no charge for a data block and you can't use data, so how is it different from having no data plan?
Anyway, I think the point has been made. Further debate will just be arguing semantics when most people know exactly what is meant.
Steve
Pony99CA is offline
The Following User Says Thank You to Pony99CA For This Useful Post:
amoren (10-16-2007)
Old 10-15-2007, 09:35 AM   #17 (permalink)
jacobburke's Avatar
Steve
MMS does not function with the data block on the Q. I get a message telling me that the message could not be sent and another telling me to check my login credentials (since the phone has to have a 3G account linked with Verizon).
Cheers!
Old 10-15-2007, 12:33 PM   #18 (permalink)
Steve
But thats what I'm trying to say, its not just arguing semantics. If you say "no data plan" then people are going to try to buy one without a data plan and we'll get more questions like "why can't I buy without a data plan". You have to have a data plan, you can't get a Q without a data plan. So you get the pay as you data plan and then apply a data block. A data block is not a data plan, its simply preventing you from using your data plan. So when you say "no data plan" your technically wrong. Go over to some place like howard forums where that question comes up three times a day. When people call up Verizon to order it they are going to have to use Verizon's terms. So telling them to say they want "no data plan" is just going to confuse the Verizon rep who is going to say they can't get one with no data plan. You have to use their terms.
remember you also don't need the data block on Verizons end, you could do the password regedit one the phone to prevent you from accidently using the data function.
Eugene is offline
Old 10-15-2007, 12:59 PM   #19 (permalink)
mrcc is on a distinguished road
not to be mean or rude. or anything. why get the motorola q or motorola qm and not get the data plan. its a must need with that phone. with so much capabilities the phone has. its like buying a computer with out the internet. but thats my opinion. its a must need. plus with the data plan it makes ur with the phone + data plan its only like 30 something a month. its pretty cheap. to get the full capabilites of the windows mobile operating system. u need to have the data plan. hell u can even connect to ur pc from ur motorola q. but u need a data plan.
mrcc is offline
Old 10-15-2007, 01:28 PM   #20 (permalink)
You can do planty with the Q without using the data plan. Its Calendar and contacts work fine. Keeping my photo albums works fine.
I look at it like this, I have the internet at home, why should I have to pay a second time just to use it on the Q, does you ISP charge you per computer, or do you pay once and then share it in the whole house?
Eugene is offline
