Old 10-07-2007, 03:36 PM   #1 (permalink)
hawkyman14's Avatar
hawkyman14 is on a distinguished road
Question Block data plan but still use WIFI?
I am very interested in getting a q9m, but I'm a college student and don't want to play the extra $44 for unlimited date. Since I am on campus there is wifi all around me. If i block the data, can i still use a wifi card to surf the web, use an IM client, and check my pop3 email through outlook?
hawkyman14 is offline
Old 10-07-2007, 04:51 PM   #2 (permalink)
Eugene is on a distinguished road
yes, the data block on;y blocks the data going through Verizon.
Eugene is offline
Old 10-31-2007, 05:50 PM   #3 (permalink)
vApor21 is on a distinguished road
Im in same situation as well.. what did you use to get wifi on your phone?? ive been reading up on the wifi sd card, but supposedly they dont work cuz of the low power outage our minisd slot gives out.. did you find out a solution?
vApor21 is offline
Old 10-31-2007, 07:51 PM   #4 (permalink)
jim9112 is on a distinguished road
it works just fine on the q9m, if you have the first Q like me then it is not possible
Verizon Q
jim9112 is offline
Old 10-31-2007, 09:40 PM   #5 (permalink)
Can you direct me to one that works well? and in addition, do i just pop it in and then it automatically just searches for connections??
vApor21 is offline
Old 12-08-2007, 02:26 PM   #6 (permalink)
jacobennis is on a distinguished road
I am also a college student and would love this feature. will it work on my Black Motorola Q? What is the best card to buy and how do i set it up?
jacobennis is offline
Old 12-08-2007, 02:28 PM   #7 (permalink)
it will not work on the original Q's only the q9's
Old 12-08-2007, 02:35 PM   #8 (permalink)
is there any way to get around this?
Old 12-08-2007, 02:39 PM   #9 (permalink)
so only the q9 and the q9m?
Old 12-08-2007, 02:41 PM   #10 (permalink)
not other than get a new Q
yea any variation of the Q9(m/c/h)
but since you are with VZW it would be the q9m
