Old 07-10-2007, 01:06 PM   #21 (permalink)
Originally Posted by felix822 View Post
Will upgrading to MOL3 wipe everything clean? (downloaded software, registry hacks, etc.)
yes it will
make sure you back everything up!
Old 07-10-2007, 01:14 PM   #22 (permalink)
felix822's Avatar
felix822 is on a distinguished road
yes it will
Thanks, I have SpriteBackup so I will use that. Should I install MOL3 myself or have Verizon people do it?
felix822 is offline
Old 07-10-2007, 01:15 PM   #23 (permalink)
i think you can do it just fine
i wouldnt waste your time with them
Old 07-10-2007, 01:31 PM   #24 (permalink)
felix822's Avatar
Thanks I'll try it tonight.
Just to make sure, SpriteBackup will backup my contacts as well right?
felix822 is offline
Old 07-10-2007, 01:33 PM   #25 (permalink)
or you could find the pim.vol file and copy that to your PC or if you use outlook just sync your Q and you will have a copy on your PC
Old 07-10-2007, 01:46 PM   #26 (permalink)
felix822's Avatar
pim.vol? Didn't know that! Thank you.
felix822 is offline
Old 07-10-2007, 01:56 PM   #27 (permalink)
i have not tried that personally but other members have
good luck!
Old 07-10-2007, 02:57 PM   #28 (permalink)
braxtoq is on a distinguished road
good luck!
I make sure I have all of the additional programs on my SD card and you can also use Verizon's wireless sync for contacts and calendar info if you're on Verizon. Also make sure you the follow the upgrade instructions to the letter.
braxtoq is offline
Old 07-10-2007, 03:02 PM   #29 (permalink)
felix822's Avatar
Thanks for all the info. But I'm not sure I want to upgrade now after reading about MOL3 and battery life!
felix822 is offline
Old 07-10-2007, 04:32 PM   #30 (permalink)
Not sure I understand you, MOL3 has not hurt the battery life on my Q at all, MOL2 increased the life significantly, MOL3 may have added even more life, definetely did not decrease it, and it is more stable as well.
braxtoq is offline
