Originally Posted by gizzle22 I Cant get my email to work at all i have been to us cellular 4 times and they are no help i set up my accounts but i cant send or receive mail everytime i try it goes back to the log in screen asking for my password plus how do i use outlook for email am i suppose to have some type of us cellular email account if anybody could help me out i would be extra gratefull |
Heres the cure for it
go to messaging>select the account you set-up and named>menu>options>account options>(select the account you named)>hit next 3 times.
at this point you should be at the incoming server and outgoing server set up.>
#1 leave the incoming server settings alone.
#2 uncheck "require SSL connection"
#3 outgoing server should be smtp.uscc.net
this setting should be used for any E-mail service provider you are having sending / receiving errors with. I currently have metrocast, that was an issue, there were also problem with comcast, roadrunner and a few others.
#4 uncheck "outgoing server requires authentication"
click next 3 more times and then done. now try to send and receive.... this WILL work ! hope this helps lots !
