Go Back   Motorola Q Forum | Everything Q > Wireless Carriers > US Cellular
Old 09-15-2008, 12:54 PM   #1 (permalink)
josh81.5 is on a distinguished road
Default Q will not transmit data
I recently purchased a Q and activated it on the USC network. It is a USC phone (I get the USC opening screen and all that good stuff). I had the data plan added to my plan (and I have verified that it has indeed been added), but I cannot send or recieve any data. When I try to access the internet I get an error message: "Login error. Ensure you have the correct login information and try again." I have contacted tech support and they made sure I had the correct NAM settings, had me do a hard reset, and a roaming update (*228), but nothing seemed to work. I have searched the internet and the only thing I could find was that some people get the message when they do not have a data plan; however, I have tripled checked to make sure that the data plan was in fact enabled. Does anybody have any ideas what may be wrong? I'm grateful for any guidance!
Thanks in advance,
Josh
josh81.5 is offline
Old 09-15-2008, 10:03 PM   #2 (permalink)
rfarrah's Avatar
rfarrah is on a distinguished road
Take it to a corporate store; let them check it out in person. Where did you get it?
rfarrah is offline
Old 09-15-2008, 10:11 PM   #3 (permalink)
aaand welcome aboard.
Old 09-16-2008, 12:02 AM   #4 (permalink)
Thanks for the idea. I recieved a new phone from them today. Same problem so I called tech support. They reset my second number in my NAM1 and it works fine. I actually typed this message on it . Hopefully this helps someone else someday.
josh81.5 is offline
