Old 12-01-2006, 11:48 AM   #1 (permalink)
cameljok's Avatar
cameljok is on a distinguished road
Default Pls help. Need to put 2 plugins on one line.
I have been editing my screens and wanted to know if there is a way to have 2 plugins on one line?? I would like to have the Bluetooth manager plugin on the same line next to the Profile plugin. The profile plugin wastes valuable real estate since it doesnt need to take the whole width of the line. I learned how to do that with shortcuts but not plugins... Please help..
thanks...
cameljok is offline
Old 12-01-2006, 01:14 PM   #2 (permalink)
troutseth is on a distinguished road
thanks...
I went looking for this a few months ago . . I came up blank. If someone has figured it out, I would love to see.
Q-tastic!
It's the network . . .
troutseth is offline
Old 12-05-2006, 04:02 PM   #3 (permalink)
inf3st's Avatar
inf3st is on a distinguished road
I know it requires the orange.dll i'd look more into that. plus there is a thread over on qusers that is very thorough on this also
inf3st is offline
Old 12-05-2006, 07:06 PM   #4 (permalink)
cameljok's Avatar
thanks i will look into that....
cameljok is offline
Old 12-06-2006, 04:17 PM   #5 (permalink)
MachB5's Avatar
MachB5 is on a distinguished road
Yes. It requires the 4orangeh.dll and WM_5regsrv.exe (close to that spelling i think). Good luck trying to find the (dll) though. I've been trying to get a hold of it for about a week solid and haven't been able to locate it. If you get it....hook a brutha up ;O)
MachB5 is offline
Old 12-14-2006, 09:00 AM   #6 (permalink)
jhalsey205's Avatar
jhalsey205 is on a distinguished road
I found the DLL:
http://www.filesend.net/download.php...18cdfa3cc1961a
but not sure where to find regsrv (or what to do with it).
jhalsey205 is offline
Old 12-14-2006, 12:40 PM   #7 (permalink)
MachB5's Avatar
keep searching on here or Qusers. there is a detailed write up ln exactly what to do once the .dll is in your application data/home folder....i just don't remember what it's called. That thread also has the regserv.exe file that you can download to your appdata/home folder.
MachB5 is offline
Old 12-15-2006, 12:40 PM   #8 (permalink)
jhalsey205's Avatar
OK, this is what I found this regarding registering Orange DLL:
Put WM5_Regsvrce.exe into \application data\home as well as the 4orangeh.dll.
this regsvr does not have a UI, so you have to register the dll manually.
open resco explorer 2003 (there is a trial on resco homepage),
select the regsvrce but don't execute!
use menu -> file -> run and enter under "arguments" 4orangeh.dll,
pres ok and restart your device.
I am not sure if this actually works...
Old 12-17-2006, 08:24 PM   #9 (permalink)
jhalsey205's Avatar
OK - I am correcting my last post. Presuming you use the Cab file referenced above, you do not need to register the DLL voa WM5_Regsvrce. Launching the cab will place the Orange files in the \Storage\Application Data\Home directory. Copy all the contents into \Application Data\Home. That's it.
John
Old 12-17-2006, 09:23 PM   #10 (permalink)
MachB5's Avatar
Why would someone not have to register the .dll? I had to register mine after it was in the 'home' folder.
MachB5 is offline
