Old 02-15-2007, 07:31 PM   #1 (permalink)
boricuafemme is on a distinguished road
Default HELP>>Im a new.
please help me to figure out, how to get Aim on my Q. and How I can get some ringtones... I have been trying to figure out all day, please help.. thanks in advance.
boricuafemme is offline
Old 02-15-2007, 09:36 PM   #2 (permalink)
first of welcome aboard.. for AIM you can Google for Agile (haven't used it myself), there are other most likely.
secondly.. there are tons of web sites that have mp3/wave/midi ring tones you can use on the Q, you can also create them yourself.
it's a good idea to connect your Q to your pc using ActiveSync so you can transfer files from one to another & vice-versa.
hope this helps...
Old 02-15-2007, 09:40 PM   #3 (permalink)
hope this helps...
thanks for replying its well appreciated... can you tell me some sites to download the ringtones,, I figured how to sync it and use my own songs but the files are huge because its a whole song. also I did that agile thing but after 7 days you have to pay for it,, is there anything that you dont have to pay for?
Old 02-15-2007, 10:00 PM   #4 (permalink)
ring tone web sites:
http://www.ringtonesgalore.co.uk
http://www.3gforfree.com
http://www.mobile9.com
http://www.motomail.co.uk
http://www.soundslikeaphone.com
http://www.mididb.com
http://www.coolfreeringtones.com
http://www.mrfreefree.com
sound search engine:
http://www.findsounds.com
there are tons more... re. the AIM, i don't use one so i can't help you any further.
Old 02-15-2007, 10:05 PM   #5 (permalink)
qnoob's Avatar
I also like browsing . . . http://freesound.iua.upf.edu/index.php
qnoob is offline
Old 02-16-2007, 01:12 AM   #6 (permalink)
bpaul24's Avatar
bpaul24 is on a distinguished road
Use the program Audacity to clip your own mp3s to 30 second clips.
Google it, there is a free version.
bpaul24 is offline
Old 02-16-2007, 11:51 AM   #7 (permalink)
thank you so much everyone,, I am gonna try all of these this evening.,
Old 02-16-2007, 12:59 PM   #8 (permalink)
did you have to install the mp3 export decoder ? i think i already have LAME installed but not sure for what :}
Old 02-16-2007, 01:57 PM   #9 (permalink)
bpaul24's Avatar
I don't believe so. There is an option on my Audacity to export as mp3.
Brandon
bpaul24 is offline
Old 02-16-2007, 03:49 PM   #10 (permalink)
I tried audacity,, but it changes the format. and it wont show up on my Q when I drag it into sounds. can you explain to me play by play how you do it. I figured out how to clip the song. but after that ,,, I was lost.
