Old 12-08-2007, 09:06 PM   #11 (permalink)
shabba122's Avatar
shabba122 is on a distinguished road
Send a message via AIM to shabba122
Originally Posted by ddodge68 View Post
Problem is...the screen rotates, when the phone is opened. So sometimes it's in portrait mode, and sometimes it's in landscape...???
that's true it does but it should automatically flip the image for you (probably making it look weird and stretched out...) a proper theme needs to be made for it...
hold on for a bit i'm seeing if i can make one for you...be back in a bit to let you know.
shabba122 is offline
Old 12-08-2007, 09:11 PM   #12 (permalink)
With the screen Would that mean its two images, or one that it stretches?
Der Alta is offline
Old 12-08-2007, 09:20 PM   #13 (permalink)
shabba122's Avatar
gave it a shot man...if you like it or if Der Alta can get the image a bit smaller we'll see how it turns out. let me know what you think and i'll upload the theme for ya. or suggest something and i'll do my best to work on it.
umm... Der Alta do you think 240x293 would work better?
Old 12-08-2007, 09:31 PM   #14 (permalink)
shabba122's Avatar
orrr this....
Old 12-08-2007, 09:34 PM   #15 (permalink)
shabba122's Avatar
here's this aswell...
Old 12-08-2007, 09:57 PM   #16 (permalink)
ddodge68's Avatar
ddodge68 is on a distinguished road
I like this...We're getting close. The little "cyclone" dude is really good, until I open the phone, and it rotates. Then the picture does not stretch...it becomes "tiled". And the "cyclone" dude is almost completely cut off. Any ideas, shabba122?
ddodge68 is offline
Old 12-08-2007, 10:07 PM   #17 (permalink)
shabba122's Avatar
umm....try this theme and see if it switches correctly...if not i will keep working on it...right now its just the big one. not the little one. this is just a test cause i was working on this one first.
Old 12-08-2007, 10:12 PM   #18 (permalink)
ddodge68's Avatar
It works fine in normal mode. Becomes tiled when I open the phone, and again, the cyclone dude is almost completely cut off.
If I could ask a favor...could you use the picture that Der Alta supplied? I like the blue background.
Thanks a ton for the help.
ddodge68 is offline
Old 12-08-2007, 10:16 PM   #19 (permalink)
shabba122's Avatar
yeah i'll work on it...but for now its rock band time...then its on to your request!!!
Old 12-08-2007, 10:18 PM   #20 (permalink)
ddodge68's Avatar
Thanks a ton. I really appreciate it. What's the rock band? You play?
ddodge68 is offline
