XML Confusion Hi, I am new here. I lurk mostly and have tried to avoid getting into this customization stuff as I was sure it would consume many hours of my life...but, alas I could resist no longer. I am not entirely dissatisfied with the homescreens that come pre-loaded on the Q, I would just like to tweek them a bit. I know HTML from the early days of web design, but I have been out of the loop in recent years and this XML business has me somewhat confused. As I understand it, it is very similar to HTML in that you can use a simple program like notepad to do your editing. Where I get confused is how to save edited files to the Q and have them show up as a selectable homescreen. For example, I was trying to edit the xml file for the Windows default layout, particularly, I want to drop the height of the calender plugin by half, and if possible change the displayed messages, i.e. 'Home Service' and 'No upcoming appointments'. It seems as though this shouldnt be too difficult and I believe I have found the lines of code that need to be edited, but, like I said, I don't know how to save the file or what extension to make it, or what is up with this version number stuff. I apologize in advance if this info is readily available and I just didnt search enough, but any help that can be thrown my way by some of you more technically savvy users would be greatly appreciated.
tia,
Ryan |
