Old 08-28-2008, 03:54 PM   #1 (permalink)
Guardian's Avatar
Informative WM6.1 Sliding Panel Res Files
Rudeboy had made a request for the clear sliding panel that comes with the new homescreens and since it was not simply located anywhere and had to be extracted, I did some digging and found them.
If you follow the homescreen code, you will find a reference to {E9267CAB-02EE-4f37-8216-6BF6A8FF5A71} which is the new sliding panel plugin and its resources (pictures and stuff) is found inside a file called brozeres.dll.
Now if anyone opens this file up or knows what to look for, you can see that everything is stored in RCDATA format which is simply binary raw data which is how they are referencing the pretty pictures and icons without putting it somewhere to be easily grabbed.
So I simply extracted, unjumbled them and saved them as hard files (which are all in PNG format mind you) and provided them to Rudeboy but I felt that those developing homescreens and so on might enjoy having access to the new high res icons and panels and so on, so I am posting the here for you as well.
If you find them useful, then I am happy to have done it, if not then I am sorry to have wasted a post and your time and you can simply ignore this. You can find all the pictures in a contact sheet format on the following page:
Windows Mobile 6.1 Sliding Panel Resources Page
There is a link on the top left of the page which will give you ALL of the files in a single ZIP file less than 500k. The file names are EXACTLY as they appear in the resource reference and have not been changed. Also, for some bizarre reason, probably just to screw with us, they have included a bunch of null files (nothing in them) but they have been provided as well just for the sake of consistency and completeness with their original names.
Enjoy!
Additional Notes:
Filename 2452.png (provides the square glass box for user pic)
Filename 3000.png, 3300.png, 4000.png, 4300.png (glass panels - rudeboy's request)
AT&T Motorola Q9h Global 6.1 (Primary Device)
Guardian is offline
The Following 12 Users Say Thank You to Guardian For This Useful Post:
BigTK (08-28-2008), cindra (08-28-2008), coppertop24 (11-14-2008), crazykay (08-28-2008), docmac129 (08-29-2008), Geekster (08-28-2008), kareljack (08-28-2008), L0c0 (09-05-2008), manbat (08-29-2008), n99hockey (08-28-2008), ninjaap (08-28-2008), rudeboy (08-28-2008)
Old 08-28-2008, 04:09 PM   #2 (permalink)
wow thats some fine work right there
Old 08-28-2008, 04:43 PM   #3 (permalink)
Guardian's Avatar
Glad to be of assistance, it is not often there is something I can do for rudeboy or the community that even comes close to what they have done for me, this was my way to give a little back within my skill set.
Guardian is offline
Old 08-28-2008, 04:57 PM   #4 (permalink)
ninjaap's Avatar
That's what I'm talkin about... Good job Guardian!!!
ninjaap is offline
Old 08-28-2008, 05:02 PM   #5 (permalink)
crazykay's Avatar
crazykay is on a distinguished road
Send a message via Yahoo to crazykay
NICE WORK Guardian!! WOW you know how long ive been studying these sliding panels trying to find exactly that!! Awesome awesome work..rudeboy will be very happy.. Sorry rb i never found this for you!! Just didnt know what i was looking for apparently!!
crazykay is offline
Old 08-28-2008, 05:14 PM   #6 (permalink)
Guardian's Avatar
Glad you like it my friend, I do what I can.
I am glad to lend a hand, you have been so nice to me, the least I could do and glad it will help you out be useful to you.
Guardian is offline
Old 08-28-2008, 05:18 PM   #7 (permalink)
kareljack is on a distinguished road
OUTSTANDING!!!!!!
Amazing job. This will help me a lot when I fiddle with my .er.. ahh.. homescreen.
Just one question, if I use one of the large icons - say a 44x44 where a 22x22 icon should go, would it automatically be set to an appropriate size that wouldnt gank the panel?
kareljack is online now
Old 08-28-2008, 05:25 PM   #8 (permalink)
Guardian's Avatar
Originally Posted by kareljack View Post
OUTSTANDING!!!!!!
Glad to help and with regards to that question, I am not sure and I will let one of the homescreen experts answer that one. Maybe docmac, manbat, crazykay, or...My assumption would be yes it will resize it down but then again since everything is XML based, it might be absolute and therefore yes it would gunk it up. I would say more likely the latter.
Guardian is offline
Old 08-28-2008, 05:29 PM   #9 (permalink)
Well.... my Yankees are in the toilet, I saw hipsters in my hood which means it's gonna turn into a trendy wankfest in about a year, and after 8 years of sucking the life and character out of NY to his rich developer buddies the mayor wants to change the term limits law so he can run for another 4 years in office... what do I have to lose??? I'm gonna swap out a mini icon with a big one and see if I bork the homescreen.
Old 08-28-2008, 05:36 PM   #10 (permalink)
No worries... I replaces a 22x22 icon with a 44x44 and it was auto-sized down to 22x22... sweeeet!!!!
Thanks again, Guardian.
