Old 08-28-2008, 05:47 PM   #11 (permalink)
Guardian's Avatar
Originally Posted by kareljack View Post
Well.... my Yankees are in the toilet, I saw hipsters in my hood which means it's gonna turn into a trendy wankfest in about a year, and after 8 years of sucking the life and character out of NY to his rich developer buddies the mayor wants to change the term limits law so he can run for another 4 years in office... what do I have to lose??? I'm gonna swap out a mini icon with a big one and see if I bork the homescreen.
when all else fails, you might as well try and find out. how I learned just about everything in life.
No worries... I replaces a 22x22 icon with a 44x44 and it was auto-sized down to 22x22... sweeeet!!!!
Thanks again, Guardian.
I figured that but wasn't sure, you are welcome and glad we know now and it worked out for you. Thanks for letting us know so we don't have to wonder.
AT&T Motorola Q9h Global 6.1 (Primary Device)
Guardian is offline
Old 08-28-2008, 10:00 PM   #12 (permalink)
kareljack is on a distinguished road
Ok... I replaced 2300 with 2302 but it is not displaying as I thought it would.
It is listed as a 55x55 size but it is really tiny on my panel.
I changed the panels (based on the mini weather theme) from slim to normal display and while all the panels are larger and the other icons are larger as well, 2302 is still tiny.
Any ideas?
kareljack is online now
Old 08-28-2008, 10:58 PM   #13 (permalink)
Guardian's Avatar
Any ideas?
Don't know what to tell you except maybe resize the image to your target dimension and THEN use it instead of trying to have them directly convert or resize. I am sorry I can't be more help but some of the designers might actually be more help.
Guardian is offline
