Originally Posted by beestea I am using one of the themes that has the counter lines for email, text messages, voicemails.
Email and Text messages work fine, however the voicemail indicator will only change from 0 to 1, but never past 1, no matter how many voicemails i have.
Is this a Sprint limitation, or is there something I can check with the code? |
See if you can PM to n99hockey, he can probably tell you if its an issue with the theme you are using.
