Old 06-01-2007, 12:19 PM   #1 (permalink)
spachman is an unknown quantity at this point
Default voicemail count question
so i have a verizon Q and th only thing i dont like about it is i cant erase my voicemail count without actually listening to my messages...
anyone know of a way to erase vmail count from the homescreen?
thanks
spachman is offline
Old 06-01-2007, 12:24 PM   #2 (permalink)
i thought i read that sprint has an option like that but i dont believe verizon does. i believe you might be stuck...
Old 06-01-2007, 04:44 PM   #3 (permalink)
as far as i know you should listen to them in order to reset the count, and well if they are (too) long just press 7 to erase while listening..
we have at least 1 Verizon person here so maybe he can chime in also, i have never heard of a way to erase voice mails without listening to them.
Old 06-01-2007, 06:21 PM   #4 (permalink)
RFI4U's Avatar
RFI4U is on a distinguished road
Send a message via MSN to RFI4U
I'm a sprint user but I think all newer Q's with the latest software should have the ability to clear the Voicemail Icon without listening to the voicemail itself.
START > Settings > Phone Settings > Clear Voicemail Icon
RFI4U is offline
Old 06-04-2007, 07:58 PM   #5 (permalink)
boricuafemme is on a distinguished road
Why with some of the home screens does it only say 1 voicemail when I have like 5?
boricuafemme is offline
Old 06-05-2007, 10:44 AM   #6 (permalink)
robknod is on a distinguished road
I have the same problem. Help?!?
robknod is offline
Old 08-12-2007, 08:20 PM   #7 (permalink)
shekiki is on a distinguished road
Default displaying number of voicemails on homescreen
have u figured out how this works yet because i am having the same problem that u had. thanks
shekiedra@bellsouth.net
shekiki is offline
Old 08-13-2007, 07:34 AM   #8 (permalink)
the problem most likely lays in the home screen.xml, you might want to try and switch the message plugin and see of that helps.
shekiki (08-13-2007)
Old 08-13-2007, 08:23 AM   #9 (permalink)
thanks so much for your help
shekiki is offline
Old 08-13-2007, 09:52 AM   #10 (permalink)
it helped or do i smell sarcasm ? :}
