Old 08-13-2007, 12:22 PM   #11 (permalink)
shekiki is on a distinguished road
it helped or do i smell sarcasm ? :}
no sarcasm,i genuinely appreciate your help. i still wasn't able to fix the problem because i'm not able to make any changes to homescreen.xml, but really thanks.
shekiki is offline
Old 08-13-2007, 01:02 PM   #12 (permalink)
copy the file to your pc.. make a copy/backup, start messing around in it, copy back to Q and see if it works. if all else fails email the .xml and i will take a look. (+ the one that works so i can compare)
shekiki (08-13-2007)
Old 08-13-2007, 01:34 PM   #13 (permalink)
great. thanks so much
shekiki is offline
