Old 01-07-2008, 06:57 PM   #1 (permalink)
dogsrule's Avatar
dogsrule is on a distinguished road
Default Using Eko's Homer but need a tweak?
Hi all, I have been using Eko's Homer screen, but where it says "no upcoming appointments" I was wondering why my next appt wont show there which is on Jan 17. I use facade, is that the problem? If i have to only view one appt, i will live with it, but it wont even show the one? Here is my ss and the xml. Thanks for any help!
dogsrule is offline
Old 01-07-2008, 07:23 PM   #2 (permalink)
I just barely started learning xml and stuff, but it looks like you don't have the Facade plugin code in the homer xml file. I'm not at home right now but you have to remove the "standard calendar plugin" code and add the Facade calendar plugin code.
If anybody else here can help you out with it, if not, I'll check back later when I get home and if noone has responded I'll post back.
MaRiA
LuvrGirl is offline
Old 01-07-2008, 07:27 PM   #3 (permalink)
luvrgirl is correct. What you're seeing is the standard calendar plugin, and not facade. You'd have to rewrite the homescreen to utilize facade.
Der Alta is offline
Old 01-07-2008, 07:42 PM   #4 (permalink)
dogsrule's Avatar
Ok thanks guys. That isn't going to happen from me as I don't have a clue. If it's not too hard could someone help me out? Please please I love homer, but I need to see when my yoga classes are.
dogsrule is offline
Old 01-07-2008, 07:53 PM   #5 (permalink)
I can help you out with it, but like I said, I'm still at work. If nobody else beats me to it... when I get home I'll check back and post back here with the edited xml file for 'ya.
MaRiA
LuvrGirl is offline
Old 01-07-2008, 07:57 PM   #6 (permalink)
LuvrGirl's will hook ya up.. so i won't mess with it.
Old 01-07-2008, 08:12 PM   #7 (permalink)
dogsrule's Avatar
Ok great LuvrGirl! Thanks
dogsrule is offline
Old 01-07-2008, 09:47 PM   #8 (permalink)
Ok, I just did this real quick and didn't load it up on my phone to test it out yet (would have to download the whole package so I can see how it looks with the homer simpson picture as background).
Try it out because I changed the "Voicemail" wording to V/M and moved it up to put the calendar plugin right below it.
If it doesn't look right or you want something else tweaked on it let me know... I'm gonna try and download the complete files and load it up on my Q and see how it looks.
MaRiA
P.S.
I saved it as homerfacadecal so you'll be able to distinguish the file and renamed the title to Homer with Facade Calendar
LuvrGirl is offline
Old 01-08-2008, 04:29 AM   #9 (permalink)
LuvrGirl, you may want to double check that code. A quick check revealed the code was incomplete. Open the XML file in Internet Explorer and it will give the location of where it's missing.
Der Alta is offline
Old 01-08-2008, 06:30 AM   #10 (permalink)
dogsrule's Avatar
I love you guys for helping me. When we have it ready for download, how do I get the new formula to be an xml file? sorry for the complete lack of know-how.
dogsrule is offline
