Thanks, Der Alta, for catching that!
Ok, looks like it's ready to go...
Dogsrule, just download the attached file to your PC.
Since we can't attach .xml files here, I just changed the extension to .txt. Go into your computer, My Computer>Tools>Folder Options>View> and uncheck "hide extension for known file types". Then go rename the file and just change the extension back from .txt to .xml.
Copy the new .xml file to your device's Application Data>Home> folder. Now go into your Settings>Homescreen> and select the new Homescreen - I titled it "Homer with Facade Calendar"
Let me know if it works for you.
MaRiA
