Old 10-09-2007, 04:00 PM   #1 (permalink)
NIGHT_OWL's Avatar
NIGHT_OWL is on a distinguished road
Default Underworld Evolution Home Screens?
Hello all........
I was just wondering if anyone knew of a home screen based on "Underworld Evolution With/SELENE) was avaliable for the Q? IF so I would love a "linky"!
Thanks N_O
NIGHT_OWL is offline
Old 10-09-2007, 09:05 PM   #2 (permalink)
-- moved --
i would say.. provide some links to images, and say it out loud you want this and usually it just pops up here on EQ :}
NIGHT_OWL (10-10-2007)
Old 10-10-2007, 01:38 AM   #3 (permalink)
NIGHT_OWL's Avatar
-- moved --
Sorry about posting that in the wrong section
But thanks for the tip Rudeboy.
http://www.sonypictures.com/movies/u...7_1024x768.jpg
http://www.sonypictures.com/movies/u...1_1024x768.jpg
I tried shrinking these two wallpaper photos down in Photoshop, but they would not open in my Q(WM wanted the app that edited them). I was able to save them as home screens but they are too big and the Facade plug-in buttons cover most of the image. Maybe someone here has some tips/suggestions on re-sizing them?
Thanks...... N_O
Old 10-10-2007, 01:48 AM   #4 (permalink)
deejmemixx's Avatar
deejmemixx is on a distinguished road
Thanks...... N_O
what all do you want in your HS?? any theme?? do you want facade? fizz weather?? if you post your requirments makes it easier to get it done. I will start some work in PS in see what i can do..although i am sure der or someone will get r dun quicker and prettier hehe.
deejmemixx is offline
The Following User Says Thank You to deejmemixx For This Useful Post:
Old 10-10-2007, 02:48 AM   #5 (permalink)
NIGHT_OWL's Avatar
Well, my current home screen has Facade launcher & the tasks/calender tabs. I have Fizz monitor & weather, but they are buttons on my Facade launcher. Really all I am looking for is to incoporate either if those images as my home screen background, but without having them covered by the Facade stuff. That may not even be possible? The same image that I use as my Q Forum pic was re-sized in Photoshop. Seems the Q would not open it(I tried IE, Opera, Core Player & file manager.
As I said I tried to resize the images, but couldn't get then open on my Q. It really is cool that you all have offered to make the home screen! I'm only two weeks into owning my Q, so I haven't been able to reaserch/learn how to do all this stuff.
I found this HS, but after installing the plug-in and the HS file my Q froze up! The HS pic would not load(it kinda just hung there and kept trying to re-load).
http://www.airfagev.com/skins1.asp?id=519
This would be a perfect HS, but in English and if it worked
Thanks again to both of you and let me know if ya need any more info on my HS.
Old 10-10-2007, 03:32 AM   #6 (permalink)
NIGHT_OWL's Avatar
Actually, is there a way to have the Facade launcher & tabs be set so that they must be "scrolled" over or selected? Like in windows XP when you have your task bar set to "hide"? I would like to have the HS pic as large as possible and only have the Facade elements show when I need them. These may be newbie questions, but as I said, I still pretty "green" when it comes to getting around my Q and its programs
By the way, I downloaded the Facade manual from their forum and so far, I haven't seen anything that would help with my HS goals
Old 10-10-2007, 05:14 AM   #7 (permalink)
Yes, there is a way to have your facade buttons "vanish" when not active. Take a look through my homescreen thread, particularly the caffeine screen and the quiet blue series, to see what I mean. I've a busy day today but if I can find a few free moments, I'll work one up for you.
BTW, saw both underworld movies in the theater. Enjoy them quite a bit.
Der Alta is offline
Old 10-10-2007, 05:21 AM   #8 (permalink)
NIGHT_OWL's Avatar
Originally Posted by Der Alta View Post
Yes, there is a way to have your facade buons "vanish" when not active. Take a look through my homescreen thread, particularly the caffeine screen and the quie blue series, to see what I mean. I've a busy day today but if I can find a few free moments, I'll work one up for you.
BTW, saw bothe underworld movies in the theater. Enjoy them quite a bit.
Thanks for the tip on the HS thread. I'll check that out ASAP. I've been checking out some of the "stickies" in this section and have downloaded 1Home Edit.
Thanks again and have a great day
Old 10-10-2007, 05:47 PM   #9 (permalink)
Didn't get a chance to get to this today. But sat down and reworked it tonight. Used a different image, though. I'll look at other images as I go tonight.
"Right Click" and "Save As"
Der Alta is offline
Old 10-10-2007, 06:27 PM   #10 (permalink)
looks good...
posted on the Q.
