Old 10-11-2007, 03:09 PM   #21 (permalink)
Originally Posted by NIGHT_OWL View Post
OK ..... I have the home screen on there but the launcher buttons are not there. Do you need to transfer the buttons individually or can ya just transfer the folder?
Are there little red "X" images on your homescreen? With the hidden buttons, you have to remember to click left and right to see them light up.
You can copy the entire folder of "Buttons" and not one by one. Just make sure you use the same file structure.
In applications/Home/ there should be two files and a directory containing the 6 buttons. It won't show up as "underworld" but as "DA_underworld_V1"
Der Alta is offline
NIGHT_OWL (10-12-2007)
Old 10-12-2007, 12:54 AM   #22 (permalink)
NIGHT_OWL's Avatar
NIGHT_OWL is on a distinguished road
Hey Der Alta..... As I said in my previous post I was just being a "dumby". I was searching for the program buttons at the very bottom of the screen verses where you had actually put them. I found the program launcher and everything works great. The home screen looks great. You did some really nice work! Thanks again!
And thanks to RB & n99hocky for assisting in the install.....
NIGHT_OWL is offline
Old 10-12-2007, 08:30 AM   #23 (permalink)
*SNIP*
no problem... glad you got it sorted out.
Old 10-12-2007, 10:05 AM   #24 (permalink)
what he /\ /\ said...no problemo!
