Old 10-10-2007, 10:26 PM   #11 (permalink)
NIGHT_OWL's Avatar
NIGHT_OWL is on a distinguished road
That is perfect! The pic actually looks better than the pics I had found. The moon in the back ground is cool too! Oh and the red makes it.
NIGHT_OWL is offline
Old 10-11-2007, 09:07 AM   #12 (permalink)
and added to the homescreen collection thread...
NIGHT_OWL (10-11-2007)
Old 10-11-2007, 09:26 AM   #13 (permalink)
NIGHT_OWL's Avatar
This may be a "goofball" question, but.........
After copying the files to Aplication Data/Home and syncing my Q, the HS isn't in my HS section in settings.
I did a soft reset and nothing.....
Any ideas...?
I almost forgot! A HUGE THANKS to Der Alta for putting that together!
Old 10-11-2007, 09:38 AM   #14 (permalink)
that's odd.. just making sure you did unzip them right ?
ETA: works on mine.
Old 10-11-2007, 10:01 AM   #15 (permalink)
NIGHT_OWL's Avatar
ETA: works on mine.
Yup, unzipped the zip file and then copied the 4 files to a folder marked underworld in Application data, Home. I synced the phone and went to settings to change the hope screen from the Facade to the underworld. Its not listed in there. I must be doing something wrong
Old 10-11-2007, 10:05 AM   #16 (permalink)
you dont put it in any folders
just the '\application data\home' folder
Old 10-11-2007, 10:10 AM   #17 (permalink)
what Scott said, all the files go into a folder called "underworld_V1_Buttons" in \Application Data\Home EXCEPT: DA_underworld_V1.home.xml and DA_underworld_V1.jpg, they go directly into \Application Data\Home.
makes sense ?
Old 10-11-2007, 10:19 AM   #18 (permalink)
NIGHT_OWL's Avatar
OK.... I was being a "dumb"! I have the HS loaded and it looks GREAT! Thanks again Der Alta! But no buttons like in the second part of Der Alts HS on the first page.
RB do the launcher buttons show in yours?
Old 10-11-2007, 10:23 AM   #19 (permalink)
NIGHT_OWL's Avatar
ETA: works on mine.
OK ..... I have the home screen on there but the launcher buttons are not there. Do you need to transfer the buttons individually or can ya just transfer the folder?
Old 10-11-2007, 10:32 AM   #20 (permalink)
transfer the folder and don't change it's name... it works on mine, remember the Facade "tabs" are visible when going over them, otherwise they are hidden.
