Originally Posted by Andyking1243 Hey,
Im trying to change the color of my home screen text and my start menu text? is there a registery key to do so? i found it on another forum but the instructions were totally different then my files |
didn't wanna hijack the hacks thread with unrelated posts.. anyway, the color on the home screen is not changed in the registry, it's done in the .xml file. the .xml file is a file that makes up your home screen, the .xml files and the images that go with them are located in \Application Data\Home\
