Old 05-01-2008, 07:50 PM   #11 (permalink)
docmac129's Avatar
Originally Posted by packers17-0 View Post
I got a question about this HS... Is there a way to have fixed shortcut icons on it? As in the icons showing up under the smiley face, envelope and telephone icons. I love the NFL hs (I'm a packers fan) but I'd really like to have the icons I choose showing up on there and not my recently used ones.
thanks.
PS. If you could make a HS that looks exactly like this but with the Packers logo or packers themed that'd be amazing!
U can have fixed icons if: 1) u have facade, or 2) u have sprint. Other than that, NO.
docmac129 is online now
Old 05-01-2008, 10:13 PM   #12 (permalink)
packers17-0 is on a distinguished road
I do have facade but if I enable the launch buttons they go accross the top part of the screen and it blocks the battery and signal meters/icons.... and if I enable those icons plus the launch buttons then it moves everything down and nothing matches up with the icons already on there... Is there a way to fix this or is that just the way it goes?
packers17-0 is offline
Old 05-01-2008, 10:23 PM   #13 (permalink)
docmac129's Avatar
There is a way to fix it. U have to go into the xml and place the plugin for the facade launcher in the space where the MRU is, and also put in padding-right with a certain number so that it pushes the launcher buttons to the left so that it fits it into that box. Confused???? If so, let me know, and I can make the changes for u. Do u know how to change code in xml??
Old 05-01-2008, 10:24 PM   #14 (permalink)
docmac129's Avatar
BTW: Too bad about Favre. I sure will miss him! I don't know off hand who the back up is, but he's got some big shoes to fill.
Old 05-01-2008, 10:31 PM   #15 (permalink)
Hey thanks for the quick reply, but I have absolutely no clue what I'm doing here... I just opened the xml file and I'm even more confused than when I first started... I'm pretty new to a wm device and don't really know what I'm doing yet... If you could help me out that'd be great!
And ya Aaron Rodgers is the starter now, altho the packers just drafted 2 qb's in last weekend's draft so I think he's gonna have some competition in training camp... We'll see prob won't be 13-3 this year but I'm sure they'll do well enough
Old 05-01-2008, 10:49 PM   #16 (permalink)
docmac129's Avatar
Yeah, I can get on it now. Red wings are kicking A$$, and its 1st intermission. Should have it in a lil bit.
Old 05-01-2008, 11:21 PM   #17 (permalink)
docmac129's Avatar
Here it is with "Fixed Icons=Facade Launcher". All u need to do to change it to the 5 icons that u want is to 1) load screen, 2) Start>Facade Settings>Menu (Soft Key)>Launcher>buttons> choose what buttons u want for buttons 1-5.
Any q's, let me know.
Peace
BTW: I didn't take any credit for making the mod w/in the xml. I left it to the original poster.
The Following User Says Thank You to docmac129 For This Useful Post:
packers17-0 (05-02-2008)
Old 05-02-2008, 12:15 AM   #18 (permalink)
thanks.
WOW that looks awsome! Thanks a lot!!!
Old 05-02-2008, 10:24 PM   #19 (permalink)
cindra's Avatar
cindra is on a distinguished road
Peace
Is the graphic on this changed to the Packers?
You poke it, you own it.
cindra is offline
Old 05-02-2008, 10:50 PM   #20 (permalink)
docmac129's Avatar
No, i just modified the SD charger screen. I will leave the Packer Screen to Golden Y, or Eko. They have the template for this screen. If they don't jump on it in a few days, I'll create something new. I try to make each screen I make a little different, & I dont like to touch others design unless there is no response from the original designer.
cindra (05-02-2008)
