Originally Posted by n99hockey just a crazy thought...have you tried to remove the plugin all together to see if they still show up...maybe its the plugin that has it built in....? |
Not so crazy... I had pretty much come to the conclusion that some plugins
have a bottom line or underscore or whatever you want to call it built in and
are unremovable such as the standard Bluetooth plugin. This particular plugin
will not respond to transparency or most other tags including the b-border="0"
.. it will only take its color from the "COLOR_HOMEHIGHLIGHT" value in the <scheme>
where as other plugins can take it from the defaults or a tag within the plugin...
But I saw this post and thought maybe this is the answer but it's not working for me..
