Old 05-23-2007, 12:53 PM   #11 (permalink)
well, if that is the case he can set the COLOR_HOMEHIGHLIGHT to whatever color his background is, or to transparent (not 100% if that works in the color section) and where he does want to see a line add it in the appropriate tag.. correct ?
Old 05-23-2007, 12:54 PM   #12 (permalink)
this is true....doesnt hurt to give it a shot
Old 05-23-2007, 04:04 PM   #13 (permalink)
Qryan is on a distinguished road
Ok, im probably gonna sound a bit stupid here, but... How exactly do i set COLOR_HOMEHIGHLIGHT to transparent? It seems that only a hex code can be entered for its value and there is no hex for transparency.
Thanks, and try not to laugh too much
Qryan is offline
Old 05-23-2007, 04:06 PM   #14 (permalink)
i suppose you could try to type "transparent"
im not even sure you can make it transparent....never tried it
Old 05-23-2007, 04:12 PM   #15 (permalink)
yea, a value of transparent doesnt work. also, it is COLOR_TRAYGRADLEFT that needs to be changed, not COLOR_HOMEHIGHLIGHT. I set its value to #FFFFFF (white), and it changed my lines to gray...odd. I will keep messing and see what I can figure out.
Qryan is offline
Old 05-23-2007, 04:15 PM   #16 (permalink)
what happens if you remove that line....
color_traygradleft
Old 05-23-2007, 04:23 PM   #17 (permalink)
hockey,
strange as it may sound, removing that line from the scheme entirely had no effect on my screen
Qryan is offline
Old 05-23-2007, 04:23 PM   #18 (permalink)
RFI4U's Avatar
RFI4U is on a distinguished road
Send a message via MSN to RFI4U
Transparency doesn't work in the <scheme> section but man wouldn't it be great if it did
It does work in the <background> and <format> tags of the plugin itself as
well as in the <default> settings for most plugins.
If you set the COLOR_HOMEHIGHLIGHT to the same color as the background it
would appear invisible but only on a solid color bg. That might make it tuff
to select something on the mru tho since lets say a black bg color with a
black highlight looks the same. What I'm finding the more i tinker is that
color tags in the <scheme> effect several things and not always just the one
thing you want to change and the things that are linked make no sense
sometimes....as an example the tag for COLOR_BTNTEXT has an influence on text that
isn't on buttons as well...
RFI4U is offline
